samplebias2
I should probably own one but I don't have a signal generator. . . is there a way to send out
a signal at +4 for (like a sine wave from a software synth) from an audio AD/DA (I have an RME USB Babyface Pro)?
I have a tube limiter I put out of calibration by trying to center the gain reduction meter, the 1-man design team
named the "gain reduction" adjust and "METER ADJUST" pots backwards IMO.
Instructions for calibrating seem easy:
"-Meter knob set to input with +4 signal adjust metr adj to zero
-Meter knob set to GR adjust to zero set it between 500 and 1000hz"
