I believe i shared this already but when I troubleshot and repaired my sump pump float controller I determined that the transistor driving the relay to switch the pump mains power failed short circuit collector-emitter ( evidence of a high collector voltage punch through).
I have seen this same transistor fail twice, first in the original unit, then in the replacement unit. I repaired the second unit by replacing the failed transistor with a higher voltage transistor I had sitting around in my back lab, and so far it is still working.
The controller already had a clamp/flyback diode in place (looks like 1n400x series). My research suggest that almost any diode can be used there, while they behave differently WRT turn-on/off times. Apparently that protection diode didn't protect squat.
