yes Gus the schemo is wrong about the rail voltages,
finally got it workin ok,
R14 is very sensitive, it changes the balance of the output transistors, 680 ohms and 2.2 K ohms have been used, we used 1 k ohms to get the DC offset reasonable at the speak jack,
R21, 22 ohms, is also very sensitive, we could not get the 5 mv voltage drop across the .47 ohm resistors with the pot, so we increased it from 22 ohms to 47 ohms and now we have a lot more range on the adj pot,
R22, 10K, did not seem to do much, so we left it out as is done on one of the revs,
this thing cranks out about 40 watts into 8 ohms, not too bad for a 1970 budget amp, sound is not that bad,
here is the final output schemo with resistor changes and voltage readings>
