Silvas, gracias amigo!! good info.
Thanks , yes I in Ecuador is the same thing, is very hard to get a good caps oR 1% resistors, The toroid transformers and cases IMPOSIBLES!!!!, HERE ONLY FIND 2X12v NO MORE VOLTS NO 15 OR 18 OR 24!!; but some times I found a few good things, now I will save the proyects and boms in mouser to record the links of especial components so when I will start a thread, buy there. Other, especially with the optos components is Allied electronics
http://www.alliedelec.com/ and newark for the OEPs transfor.
Now I am spending my time making only the PCBs at home of some proyects, (Kroc opto compressor, what comp, Green, PSUs, G1176 and SSL, 312 and 312 psu, balancing amp, ) while I WAIT FOR THE ARRIVAL OF THE KROC´s and GREEN´s MIC PRE COMPONETS FROM MOUSER and Allied Elec. USA TO ECUADOR!!. I m using the Lazer print and transfer method on a virgin copper PCB. So when I will finish a thread... then I will have the PCB of other thread ready to use; is very therapeutic the PBC making ja ja aja!
I will try to experiment with the components that I find and I listen your advices, maybe I will make a list with the comun resistor and caps for to use in pro audio DIY, so I will buy some of thems in mouser or other stores. The bad things is in Ecuador we pay a harder tax for the imports, if you import + 8 lbs or more $400 you pay taxs + IVA, and other internal taxes!! to much money!!! I need to buy "de a poco" sptep by step.
thanks for the advices
regards
mucha suerte y chao
Juanjo
