Blackdawg
Anyone heard from Cemal lately? I was in process of getting an order done via email for a custom rack mount PSU and a 11 slot rack. But haven't heard from him in weeks.
Hello,Blackdawg said:Anyone heard from Cemal lately? I was in process of getting an order done via email for a custom rack mount PSU and a 11 slot rack. But haven't heard from him in weeks.
kante1603 said:Hello,
yes,he is posting here,just do a member search and look at his posts.
Personally my last contact with him was only two days ago.
Maybe wrong email adress?
Hope to have helped,
Udo.
The adress is right,the same I use....maybe it went to the spam folder at Cemal's side?Blackdawg said:Hmm. Interesting.
I was using [email protected]
Had had several responses before I had to get in touch with Jeff at CAPI to ask about current draw for the ML2. Once I had the numbers i replied, but never heard back.
I'll just try again!
kante1603 said:The adress is right,the same I use....maybe it went to the spam folder at Cemal's side?
And I know Cemal is very busy these days.
Please try again,if it fails again I can try to contact him for you if you want,though as said I use the same adress,but mine never went to the soam at least.
Please keep us posted,
best regards,
Udo.
sahib said:However, I can (and have done for a number of users) trim the floorbox case to make it shorter for a triple output. See attached image.
Hello,miscend said:Your website isn't working, i'm getting a 404 error clicking on any product page. I'm just trying to order a module extender.
sahib said:Hi Matthew,
We can have it at 200mm x 260mm x 70mm. See attached image. If you open it in paint and at 100% it is half the original size (100mm x 130mm).
We can trim the length further down to about 220mm but we have to mount the single +48V board to the back of the front panel. You will obviously see four screw heads on the right hand side of the front panel.
However, please note that this can only be for VPR (+ -16V and + 48V) version not 51x.
Kind regards,
Cemal
