500 RACK / EQ ONE , MICPRE ONE, MID-SIDE ONE by Total Audio Control
Status
Not open for further replies.
kante1603
Munich,Germany
Hello,
I´m proud to present my "TAC expansion":
10 channels of finest audio gear,driven by only one psu (TAC PSU ONE custom,becomes hand warm only!).
Will show a bit more in a TAC PSU ONE here:
https://groupdiy.com/index.php?topic=64373.new#new
Have fun,
Udo.
P.S.:Edited to insert link.
fragletrollet
GDIY Supporter
Oslo
sahib said:
1U RACK MOUNT POWER SUPPLY KIT
Can power two 11 slot racks (22 modules).
AC INPUT: 115/230V
DC OUTPUT 1:  + - 16V @ 3.5A or + - 24V @ 2.4A
DC OUTPUT 2:  + - 16V @ 3.5A or + - 24V @ 2.4A
DC OUTPUT 3:  + 48V @ 300mA
GBP 350.00
Isn`t the vpr spec 130mA pr slot? Does this mean that each of the outputs can power 22 modules, and the whole rack psu can power 44?
kante1603
Munich,Germany
OneRoomStudios said:
Are there any plans to release any smaller/less expensive PSUs for the 6U and smaller racks?
Cemal offers the FB1 and FB2,please see page one here.
If you want it even smaller then you might want to go a different route,there are lots if possibilities.
Hope to have helped,
best regards,
Udo.
sahib
Glasgow - UK
Thank you Udo.
@ OneRoomStudios
I am not sure if you mean the 1U rack mount or the floorbox  but if you let me know what your current requirement is then I can put a configuration for you.
I can not modify the 1U case itself but I can configure it for a lower power version which offers some savings.  However, I can (and have done for a number of users) trim the floorbox case to make it shorter for a triple output. See attached image.
Blackdawg
Wyoming/St. Louis
What does the 2nd DB25 connector on the 11 slot do? I see the first 8 inputs have DB25 inputs and outputs. But then there is just one other DB25. Is this the I/O for the last 3 channels as in both in and out?
Blackdawg
Wyoming/St. Louis
sahib said:
The 3rd one is for slot 9 /10 inputs and outputs.
Slot 11 does not appear on SubD25.
gotcha! So its also the aux sends/sends&returns for 9&10?
Also i don't see the rack mount PSU on your site. Is it still available?
sahib
Glasgow - UK
You can certainly use them that way for mixer applications. In fact the slot 11 is also designated as the monitor channel and the auxiliary pins are available separately on a 10 way header. Also,  although I deliberately obscured it on the rear view picture there is actually an extra hole on the rear panel for a 4th SubD25 connector at the bottom left.
We currently supply the built versions on our web site ( that's why the prices are higher) and the 1U rack mount PSU is not there.  All the kits are sold through here in the White Market and the rack mount PSU is available as kit.
Blackdawg
Wyoming/St. Louis
Fantastic!
You have my business. Just ordered my final two 500 cards to fill my current rack. Will be in touch to get a 11 slot and rack mount PSU soon!
Thanks for your responses!!
Monte
OneRoomStudios
Minneapolis, MN, USA
What would the price be for the shorter floorbox PSU? Thanks!
sahib
Glasgow - UK
The shorter one would be FB1 type with + -16V and +48V for VPR operation.  There is no change in the price as there is no change in the number of components used.
However the power supply is GBP 170.00
The shipping options are as follows;
Landmark Global World Economy GBP 23.00
I have never used this service before. It gives 10 days lead time but I suspect it will be longer than that.
UPS Express Saver GBP 35.00
Lead time  is normally 5 days but again sometimes it takes a couple of days longer than that.
Regards,
Cemal
3nity
MTL, CANADA
Hi Cemal.
Regarding the 6 slots lunchbox.
Why do i count 7 slots instead of 6?
im counting the mounting holes for modules!
Am i wrong?
sahib
Glasgow - UK
No sir, you are right.
1, 3 and 6 slot racks all have one slot space extra. This is firstly  for 2 unit wide modules that are mono, such as our EQ ONE, so that they do not take up a usable slot.
The second is to accommodate the mains transformer for the on board power supply. I have not listed it yet as I have only recently finished it.
elskardio
Montreal - Canada
Wow this looks great !  8)
Any idea for the price and availability?
sahib
Glasgow - UK
Thank you.
It is available.
I have split the kit into two parts.
Part 1: Essential Kit.
This  is the essential kit consisting of all of the design specific components, such as the metalwork, heatsinks, fuse holders etc.  which I supply. Please note that this consists of two modules. One is the regulator module and the other one is the transformer module.
GBP 145.00.
Please note that for UK and EC purchases the VAT will be added. There is no VAT for the rest of the world.
The kit includes;
2 x Faceplate
2 x Backplate
2 x Stick-on facia
2 x Screen plate
1 x PCB
2 x Hex pillars
1 x Earth eyelet
4 x Fuse holder
1 x Mains Switch+ Cap
1 x Fuse booth
1 x Mains switch booth
1 x Heatsink for TL783
2 x Heatsink for LM317
3 x Thermal pad
3 x M3 Screw+bush set
4 x 2 Way terminal block 3.91mm pitch
6 x 2Way Terminal block 5mm pitch
3 x 2mm LED
2 x 1k5
1 x 4k7
20 x M3 Screw + shakeproof washer
Part 2: Active and passive components.
These are the active and passive components which you can  purchase locally or may even have in your stock already.
+48V RAIL
1 x Bridge rectifier
2 x 1N4003
1 x 150R
1 x 5k1
1 x 1K trimmer
2 x 470uF100V
1 x 47uF 63V
2 x 100nF
1 x TL783
+ -16V/24 RAILS
2 x Bridge rectifier
4 x 1N4003
2 x 240R
2 x 2k4
2 x 1k trimmer
2 x 4700uF 35/50V
2 x 1000uF 35V
2 x 100uF 35V
4 x 100nF
2 x LM317
4 x 20mm Fuse
The mains transformer.
For my prototyping I have got the one in the pictures made by Avel Lindberg with 2 x 16V and 1 x 48V secondaries.  It is encapsulated, with an internal mu metal band and interwinding electrostatic screen. One off price was GBP 45.00.
The mains switch.
Panel plug:
Bulgin PX0429,
Rapid order code: 23-1215
Cable socket:
Bulgin PX0646
Rapid order code: 23-1210
I will start a build thread in the lab but in the mean time I have cobbled a series of photographs showing the assembly sequence.  Link to the images.
http://www.robotica.co.uk/tac/500_psu_assembly.jpg
Here are some general pictures.
The transformer shown is for only single slot power. The module can take a larger one to power upto 3 slots but anything above that requires additional slot as the transformer height will increase.
Status
