Grampian 636 distortion/saturation box - what input transformer? +cutting spring reverb
Urskov
Denmark
Hi DIY'ers
Me and an internet partner are in the middle of making/designing a Grampian 636 without the spring reverb - for pure germanium filth/saturation/distortion, as it was famously used by Pete Townshend. (Eventually I might want to add the spring and make PCBs available)
The Grampian 636 commands extreme prices, so we thought we'd do it ourselves.
Here's what we got so far - schematic. It also has the questions about certain parts of the circuit marked in.
Notice that since this circuit runs on primary -12v, we decided to add a voltage inverter and doubler with a 79L12 voltage regulator.
Here is tons of documentation by Soundgas that themselves made a clone for a whopping 5300 USD o_O
https://soundgas.com/resources/grampian-636-instructions-schematics/Schematic: https://soundgas.com/wp-content/upl...pian-Reverberation-Unit-Type-636-DEST4328.pdf
Technical specs: https://soundgas.com/wp-content/uploads/2019/01/Grampian-Reverberation-Unit-Brochure_p1.pdf
So our main questions are:
- Have we proceeded correctly with cutting the spring reverb? We want as much of the "mojo" of the circuit for the saturation, so the more of it we can include, the better.
- What transformer can we use for the mic pre? And how do we wire the balanced and unbalanced channels of the mic pre?
Let me preface this by saying I have no experience with this Grampian unit. Are you sure you don't need the reverb part of this for the full "mojo" factor? If you take a blackface Fender Deluxe reverb and get rid of the reverb.............you have lost a good part of the "mojo" IMHO. Just my 2 cents. Also, on the schem where you marked add vol control, it should work fine to replace that with a 50k pot wired as a volume control. It would function as a master volume.
Yeah, I definitely want that in the long run, but for starters it's gonna be part of a vero layout blog for guitar effects.. so we want this layout for simplicity
Dont forget , theres also a lightbulb limiter in the path to the spring on the Grampian .
I'm still laughing about that one after opening that up expecting something serious. I think the Mosrite fuzz (at least what I can remember) was about the worst distortion I have ever heard, although opinions vary. At least after those 1N4001's you'll truly have achieved brick wall limiting.
Funny! I love the sound of the Fuzzrite, built one myself... It¨s the sound of La Gadda Da Vidda, not to mention in the soundtracks of countless spaghetti westerns. Piercing and thin, but just right.
Yeah, that's the thing.... we all have our various taste's insofar as what sounds good. Whatever works for you. For me I tend to like smoother distortion tones, something more like certain tube amps.
A harmonically simple source like an electric guitar can take quite a bit of THD before it becomes objectionable ,
voice is way less forgiving , at times choral voices can intermodulate and create a horrendous din even if the signal path is completely clean , even percentage points THD in the low end on something like an electric bass remain innocuous enough to most people , conventional drive units wont have a hope of reproducing low bass frequencies with the same magnitude of distortion that your modern ADC/DAC can do in any case .
Hi @Urskov, did you end up building it?
Sadly, I didn't. I tried setting the circuit up on a breadboard, but I quickly grew disheartened due to lack of knowledge... @Jahlousie that had the know-how began the project with me, but I think he dropped it, too, due to lack of time.
I've been spending the last year learning about simple tube gear (mic pres and guitar amps) instead.
But I still REALLY want one for my studio! So if you have (some of) the know-how, let me know how I can help.
Thought I would revive this thread and chime in as I have been on quite the germanium binge recently. I've decided to start trying to simulate this weird, weird circuit!
The SVA replica doesnt look accurate. This French guy seems to have done a faithful reproduction though and it isnt much more expensive than the SVA. I mean the SVA guy hasnt even used the right transistors..anyway check this:
https://reverb.com/en-fr/item/69285...electro-kinetiques-micpre-reverb-replica-2023
I would just build it into a rackmount like soundgas but yeah... f*** soundgas. 5-6 grand? for a clone?
The input Xformer is a simple type preamp input transformer. Usually come in a chrome metal cube. i have some lying around workshop and if they work I'll leave inductance data etc. here..
Does anyone know what Reverb Tank code is the stock one used? Most reverbs from that era in my experience use those Hammond F types.
And lastly, really would like technical data on the interstage xformer. Will jump over that hurdle when it comes i guess.
I actually had a go at building this sometime in 2023 but never got it working so it's been in the scrap pile ever since. Stumbled across this thread again and decided to dig it out as I have a scope now. After a very quick test, I'm seeing all transistor voltages are way out (most collector voltages are far too high), but not much to indicate why. The audio signal starts asymmetrically clipping on the collector of Q1 which scales with the volume knob, and then the signal gets lost after Q2, likely because it's so out of bias. I can provide voltages if anyone is interested.
Has anyone else attempted this build? I'd like to at least try to get it working before I just buy the Behringer unit hahaIMG_1043.jpg
Replacing emitter resistors with trimmers could allow you to adjust the bias to be correct. Getting the bias correct should be step #1 before assessing anything else.
I can almost guarantee the "why" of the bias being off is due to differences in the performance of the transistors you used vs. what was used in original units. Germanium transistors especially have a reputation for being all over the place bias-wise. It wouldn't matter if you used the exact same part number as the original, if you got ones that are more leaky (or maybe even less leaky!) than what they designed around, bias will surely be off. And these designs are simplistic, meaning they don't have any means for tolerating wide variations in transistors. Adding adjustable emitter resistors is a simple way to get some amount of control to dial it in to functional with the transistors on hand.
