GssL 20th Anniversary edition
No problem Gustav, I removed the files. I leave the rest with the builders. Once I have more information on the color module implementation, I'll chime in. Thanks!
Like I said, I dont mind you curating it, if you want!?
You can even just do the BOMs, and post the links. I will happily replace the links in the first post - I just dont want to go over excell sheets and do the work with your approach, cuz I find, that most times, something pops up for a correction with real-world experience anyway. At this stage, thats what I would rely on rather than rechecking lists more times.
Gustav
And you can always leave it out or put something else in there. I have seen, you can buy vero-boards in the format to clip on.
Below it stands a little more finished.
I need to change out the scale on the meter, and I dont have any colour modules to do that final test with yet before signing off on the project completely. It will work, its such a simple part, but you just never know if theres something that will warrent a small change to the Gerber.
Knobs I used are from Sibalco.
Remember, guys. This is DIY, so you dont have to ask me for a different scale or design or adding power switches.
Im happy with the design I did, and I did it mostly to share a panel with the standard values.
Just do you own!
Gustav
Just do you own!
Gustav
Hi Gustav. What size is those knobs and where did you buy them? I want some BIG knobs to :D
Think I'm pretty much done whit my front panel. I attached the fpd file if anyone want it as a base to adjust further.
  • panel_20th_VU_S500_Andado_V2.pdf
    37.9 KB
  • panel_20th_VU_S500_Andado_V2.fpd.zip
    6.2 KB
Great project, is it possible also to make LPF. Soms in dance music you wil not to compress nothing above 15khz. Then you can compress to the taste of freq spectrum reference. This thing wil be the also good and flexible as mastering compressor.
I'm almost done creating the sectioned BOM for mouser for anyone interested. The only things I'm missing and I'm not sure about are the signal relays and the IDC male & female connectors. If anyone has the mouser equivalent for those , I can add them and share the finished BOM here .
It's a bit on the pricey side since I chose TDK , Vishay & Kemet caps but nothing too extreme
I made a final calculation, let me know if i can optimize the costs. I'm transparent about the costs & sharing:
https://1drv.ms/x/c/941ffb6171f959d4/ER9htp_TrbZGl9MojtugTSoBNxOVPSI5aGMlgk3Sc_Fo_w?e=AjOx0m (Online Excel)
In order to get the Link working, you need to copy and paste the whole URL, direct linking does not work for some reason...
So more or less, it's between total of 31 up to 48 EUR depending on location
Paid, then thought how would he know who i am? but i'm the only one from The Netherlands on the list ;)
