[quote author="okgb"] Start either at the input or back from the output , stage by stage
and see if you can find out where the signal goes wrong , stops
amplifying ? [/quote]
here are some datas:
Vin= 2 Vpp
Vsec=6 Vpp (secondary windings of trafo going to PCB)
Vout=0,5 Vpp (output of GR gain set to minimum.
I am using a OEP A26A3E trafo and I am testing the boards without side and top lid of the case.
wired as follows (NOTE the pictures shows a OEP A26A
2E instead of a OEP A26A
3E):
The distorted signal appears at PIN3 of the Hi-z input (before R9) and without the jack connected it has an amplitude of 10mVpp, while with the jack connected it's 75mVpp.
PIN 2 it's just fine and it has an amplitude of 6 Vpp.
Does it looks like I am doing something wrong with the connections??
could anyone please post how they connected the components off board?
IE: trafos DI input etc.. I think that will clarify many things.
many thanks.
