okgb said:Shouldn't be much different than the " official " one
check the documents section.
Dan Kennedy said:14va is fine.
The boards draw about 40ma each.
In a quick test with a 22v transformer and a variac to run it up some a 47 ohm resistor in each leg is about
right to drop the resultant dc at the filter caps to about 40 volts, which is fine for the 317/337 pairs.
You'll need 5w rated resistors, they'll get warm.
There are a lot of variables, this is a reasonable place to start.
Put a 20 ohm 2W resistor in the feed to the voltage doubler, this will drop it down some, you might want
to put a load across the filter cap at the output of the doubler as well, maybe 2.2K also 2W. This will help
hold it down too.
Sredna said:Be shure to double and triple check the power connection to the boards!
dmp said:My pair has a pretty noticeable buzz when using the unbalanced out. I don't have transformers in yet for a balanced out.
Other than that they work correctly. I was able to null the output to about 1 mV with R46.
I used a copper rail along the back XLRs to a chassis ground point, connected the power ground to this point as well, and the 3rd prong of the power cord.
