Hi All,
I would appreciate any help anyone can give that address this specific query.
I am putting direct outs in (unbalanced, because I have little time to rig something else).
I can do a mod with just TS wire, BUT: I have lots of TRS wire lying around. Are the following things TRUE?:
1) I can use the TRS wire as long as I ground the shield on ONE END ONLY?
2) all GROUNDS are the same, and therefore, I can ground one end of the shielded DIRECT OUT cable to the SAME GROUND used by the XLR input?
3) if 2 above is true, then doing it this way with shielded wire, one end grounded, will give you just a bit better signal protection than just unbalanced via TS cable?
Thanks! I love you!
Boom
Thanks! I love you!
Boom
