i see no plate choke, that circuit is therefore disqualified,
Ideally, they should go to the chassis ground, but in fact in most cases they can go to any reasonably stiff reference node, meaning they could go to a cathode decoupled to ground, they could go to B+ (would be silly because' of risks), they could go to DC heaters voltage... connecting them to 0v is OK, except if there's heavy HF energy in the box; then, the metal parts, acting like antennas, would discharge the energy in the 0v node, which is not a nice thing to do.earthsled said:Does anyone have recommendations for grounding tube shields and transformer shields on a PCB? Should they be tied to the chassis, or should they go to 0V of the audio circuit?
There's stuff here that really should be put in the Meta pages, imho.
The ground plane must avoid the CT and the smoothing caps gnd.dmp said:Going back to the dual ground v3 gif - I would be interested to understand better the flow of current and how that might create noise. This seems to me to be the necessary building block of information to create a quiet PSU.
The sketch makes it seem that a common ground for the rectifier, filter caps, and regulator will create quiet power rails. But isn't it true that all the current returns to the transformer center tap, which is at the opposite end of the ground flow from the audio ground return? This seems to me to be problematic, as the ground plane (say it is a copper wire) between audio ground and the transformer CT will be fluctuating slightly depending on the current going through it? If the ground reference for the regulators is fluctuating slightly (i.e. noise!) then the power rail will have some noise in it, yes?
So the regulators and audio ground plane should only connect to the CT and smoothing caps ground in one place? I'm not sure exactly how to interpret 'avoid'.The ground plane must avoid the CT and the smoothing caps gnd.
There is a voltage that develops along the conductor that goes from the smoothing caps to the CT; this voltage must not be allowed to pollute any other ground.dmp said:So the regulators and audio ground plane should only connect to the CT and smoothing caps ground in one place? I'm not sure exactly how to interpret 'avoid'.The ground plane must avoid the CT and the smoothing caps gnd.
I'm still visualizing all the current from the regulator and audio circuit returning to the CT and smoothing caps. Is this an incorrect way to think of it?
CJ said:audio grounds should be star grounded but if two channel box, use different star grounds for each channel.
CJ said:i built a 2 channel guitar amp one time and one channel had less hum than the other, even though each circuit was identical. the channel with the most hum was further away from the power trans, so why it had a tad more hum is still a mystery. :
