[quote author="cjenrick"]I mean do you follow certain rules like all mic level stuff is XLR, (obviously), and all line level stuff is 1/4 inch phone jacks? If so, how do you keep from grounding your 1/4 inch jacks? [/quote]
XL to XL always
Mic and line
BUT :shock: when I must .... :roll:
for 6.5 mm stuff I ALWAYS use the stereo version and then make my mind up on wiring to suit the occassion
this one pictured is unusual as it is tip and ring only
also come with a plastic nut and available as switched with PCB mount. That's what I usually get and one unit can be used in ALL situations.
and for RCA's
A panel of multiple RCA's
available as 2-way, 4-way, 6-way and 8-way panels
EVEN better are the units built into the usual XL chassis type mounting.
BUT I'm too tight to spend that much.
