jordanazor said:
Is there a way of stacking pres using the cascading system? ie Could I engage 1 (pre) 4 (EQ) 9 (compressor) and audition that chain in sequence through the mic in 11? And hypothetically change one element at a time? Keep 1, 4 the same but try a different EQ on 10?
No, because it is not a full matrix router. (You can do that with a patch panel of course).
I called it Cascade because it allows
sequential routing. With the Cascade daughter card you can stack any 2 or more SEQUENTIAL cards, left to right. Some API racks (Radial, Cartec) have this capability do it with switches on the back of the rack (no relays) and call it "FEED".
Examples:
Say you want to put a little compression on (for tracking, or for singer monitoring, or to do out of the box compression after summing but before printing to digital/tape).
So you have a mic pre in 1 and a comp in 2
If you switch on relay 1 you will accomplish the following:
A mic plugged into input 1, will be amplified by module 1, compressed by module 2, and the signal output on 2.
Similarly if you have a pre in 5 and a comp in 6, you will create a similar short channel strip inputing on 5 and outputting on 6.
Of course you could add an EQ and you would use two relays to link the three modules, then your virtual channel strips would be 3 modules long.
And the outputs of each module are still hot, so you can track the output you want.
The Channel 11 card is different
Say you have a bunch of preamps and you think for this vocal you might want your SSL 9K in there, or you might want something dirtier - say a 312, or a tube pre.
It can be slow to compare which sounds better (stop, turn off phantom, switch mic cable patch, power up phantom, etc) by which time the singer has wandered off or moved or gotten bored.
With this cascade card you can set up two preamps to compare, and then move the input from one to the other (you could have the output's mixed so your levels matched). Since you provide phantom at Channel 11 - you don't need to change that. It is quicker.
Or you can switch both input and output. The channel 11 card patches OUTPUT to OUTPUT and INPUT TO INPUT. So the signal delivered on the Channel 11 output is whatever you switch it to be (including off). Channel 11 produces no output of it's own. Same for input (except that channel 11 input is capable of providing phantom power, even when it is off). You can obviously use the Channel 11 card in combination with the Cascade card. And compare two different signal chains the same way.
The outputs just switch by activating one of 10 relays. The Channel 11 input pins (2 and 3) have capacitors between them and the preamps to address possible phantom power noise/problems when switching but other than that, it just activates one of 10 relays.
The cards fit under the existing connectors between the back panel and the backplane. I put the relay cards in the back of the case for several reasons. First it keeps the signal path short. Second it leaves the whole rack "unscathed" if you want to use all 11 channels. If the relays are unpowered, the Rack works just like a GDIY 51x rack on all 11 channels. Lastly you might want to control the relays in various way, anything from mounting switches on the back to building your own modules to control.
Limitations
The Channel 11 card lets you choose any input or output from 1 to X, where X is <=10. The cascade module lets you chain any to modules together from the set 1-9 (you can't chain 10 and put it into output 11. Conceptually it would work, but I wanted to keep 11 open for other things).
The cards do require a TASCAM Card, but they don't require you to punch the holes in the back of the case unless you want to USE TASCAM. The TASCAM Card just deals with the 50 pin connector available on the GDIY 51X rack and routes it to a daughtercard. You can mount the cards in the back of the rack without exposing the TASCAM DB25 pin connector. Right now it appears that I can stack 1 daughter card with 1 TASCAM card, but I may be able to solder two daughter cards together (spacing will be tight) I will let you know when I get them. Two TASCAM cards can fit in the back with room for a daughtercard each.
