My understanding is that since that board gets very hot, there are cases where the actual board starts to become conducive due to becoming burnt and turning into carbon.
jslstudio said:Received my kit. Looks great came out great.But, The one thing that I think needs to be addressed is the PSU Turret board.
It barely fits the original 10ohm and 30 ohm Koolohm resistors.
And In my opinion to thin.
These Boards get very hot!!! I ave a original....It twice the thickness almost then the kit one. And the turrets should be large
on the PSU board.
The good thing is this board is easy to make. But It is to small and thin. Just a Heads up...It will work.
But should be thicker and more spaced out for the original Koolohms.
Git looks great though!!! Nice work......
John
diylan said:Hey Martin,
I received my kit a couple days ago. The build quality looks great, but there's an issue with the faceplate... it looks like the lettering/design was silk screened on the wrong side!
I have attached a picture to show the issue. Please let me know what you think would be the best way to handle this.
For anyone that received a package and put it away for the future, I would encourage you to double check as well.
mutterd said:Hey everyone - I’ve looked thru the thread - so I apologize if this has been covered - but can someone confirm the size of the big and small knobs on the original?
I’m guessing it’s 2 1/8” for the big ones and 7/8” for the small?
Is that correct?
Thanks.
Timothy
rainton said:diylan's new faceplate is on its way I heard
I also attached the first screenshots of the illustrations I made for the wiring layout - here's the upper pcb front & back:
and the lower pcb:
It's all gonna be part of the wiring layout that shows all components - but I'm still working on it - here's another screenshot:
It's a ton of work though.
I'll put together a folder with all the build pics I made while building my prototype and share the link directly with all members of the group buy...
For now here's the corrected schematic (as mentioned before there were quite some errors in there):
http://www.mediafire.com/file/w1wa7eti78ytc3s/Universal_Audio_176_Schematic_CORRECTED.pdf/file
And for those who haven't received it yet the V0.2 version of the BOM. There's no BOM with Mouser links etc. yet, but you're welcome to contribute![]()
http://www.mediafire.com/file/zr69mu542424vfy/analogvibes_176_Parts_List_rev.0_2.pdf/file
Many builders are also over in our analogvibes Facebook group - might be worth checking out for help:
https://www.facebook.com/groups/analogvibes
hope that helps for now
Martin
Other pcb boards are good. And mil is good. Just PSU.salomonander said:ps: is this the case for the psu board only? that wouldn't be too bad. devil sits in the detail![]()
