BramK
Very helpful! Thanks for the general walkthrough Paul, and the PSU mounting tip, Molten. I'll post progress pics and any questions that come up along the way, aiming to get started next week.
Phrazemaster said:Are these capacitors OK for the build?
I'm not sure the quality of Sprague paper in oil - I read somewhere the paper breaks down and that can degrade/damage the capacitor...
Thx all
PS having trouble finding the right lamp holder...does anyone have a part number or know what exactly was used? Thx!
WOOT! ;DBramK said:And thanks Phraze... Looking back through my emails from last year, it looks like I ordered and paid for the numetal version but was sent the open frame by mistake. I've contacted Sowter to see if they'll exchange it.
Kosi posted a link to a mounting plate awhile back; not sure if it's for the right capacitor (sorry), but may this helps...BramK said:Hey Paul, I've been trying to decipher from your build photos how you mounted your Hayseed can caps to the chassis, but it's unclear. Any insights there?
kosi said:you need a mounting plate inside
https://www.tubesandmore.com/products/mounting-plate-metal-1-can-capacitor
you can also use one for the other cap with 4 "slits"
BramK said:Potato Cakes said:Hey Paul, I've been trying to decipher from your build photos how you mounted your Hayseed can caps to the chassis, but it's unclear. Any insights there?
How are folks mounting the API Meter?
The mounting plate are indeed how those caps are mounted. Be sure to get the appropriate sized ones as each cap needs a different one.
There is mounting hardware included with the API meter. It fastens to the front panel similar to how the Hairball meter is installed on their FET rack builds. I think you can see how it's done on some of the photos posted on this thread.
Paul
core13 said:I would like to know if the 2 psu resistor value must be changed when using the 370bx because it deliver less voltage.
also if someone know what are the original radiall film capacitor C3 and C4?
thank you
moltenwok said:Here's a side shot of the mounting
Potato Cakes said:The wiring guide prescribes either the 372 or 370x with no correction to the PSU, so I would imagine you would probably be fine. However, if you are looking to modify the PSU resistor values to accommodate the power transformer, you can simply do some good ol' Ohm's law as you know the target voltage drop per resistor based off of the UA176 schematic to calculate amperage then use that and plug in the voltage based on the 370x (370x voltage from the GZ34 minus the target voltage).
Paul
Phrazemaster said:Another Question about the CE cap (C11). There's 2 listed at tubesandmore.com
https://www.tubesandmore.com/products/capacitor-ce-mfg-475v-20202020-f-electrolytic-25-height
They both have same electrical specs, but one is shorter and fatter and the other longer and skinnier. Or so the pictures seem. But they both claim to have bottom diameter of 1.375".
Anyone has bought this cap (C11) and knows which is the right one?
Mike
core13 said:Thank you paul
I think I will use the 370bx
I will do my math and see
edit.
the 370bx deliver 2x275v instead of 2X325v
on the schematic going from ac to dc with GZ34+Choke 10HY add 40v
maybe with the 370bx it will add also 40v or maybe less like 35v
so 275+35v=310v
310V is the voltage needed after the first dropping 1,5k resistor (R44).
too much resistance is going to reduce the voltage on the 12BH7 plate.
so do I need to remove completely the first resistor?
put only 300ohm or something and lower the second resistor (R43)?
Thank-you Paul. It's strange they have two nearly identical - and also fail to put the dimensional differences on their site...Potato Cakes said:Regarding the externally mounted capacitors, you have plenty of room in relation to adjacent components that it wouldn't matter if you go with the fatter ones. For the one that mounts to the PCB, you will probably want to get the skinnier version to ensure it fits through the opening in the back of the chassis.
If you're really uncertain then go here:
https://hayseedhamfest.com/products/ua-176
This is what I used and it works great. I believe this is where Martin got his caps for his prototype.
Paul
