So....anyone want to share what capacitor you used for C3 and C4? Looks like electrolytic...Phrazemaster said:This thread is starting to sound like an echo chamber...isn't anyone else building or gathering parts?
I was also wondering what folks are using for C3 and C4. In Martin's pix it looks like he used tall electrolytic-looking caps, but there is no side shot so I can't tell. The only film caps I can find that might be appropriate are some orange drops (which I've seen used on originals). But they don't match what Martin used.
So what did you guys who already built use for C3 and C4?
Mike
Phrazemaster said:Thank you Paul. I sourced some orange drops but I think they would look funny there.
Anyone know what the originals used?
Martin, what did you use for C3 and C4?
Thx everyone,
Mike
jslstudio said:OB 2 should be Very bright and red....You have no power to the tube.....
Greebok said:If I pull out the 6BC8 the OB2 shines as a normal tube.. If I insert the 6BC8 back the OB2 looks as a dead tube..
I've tried various OB2's but no result..
I checked many times all the cables and wiring.. I couldn't find a mistake.. it started to drive me mad :-X
Potato Cakes said:Might not hurt to measure C1 and make sure it is indeed 0.1uF and connected properly to OB2 and ground.
Potato Cakes said:Might not hurt to measure C1 and make sure it is indeed 0.1uF and connected properly to OB2 and ground. Also make sure that ground connection of OB2 is also good.
Greebok said:Are you sure about the C1? It's 0.47 uF btw.. Maybe do you mean C10 ?
