Harpo
different pinoutspreadspell said:... and use instead of this an Omron G2RL-2 (24VDC)...
Harpo said:different pinout
Your pin extension only adresses the different pin spacing.spreadspell said:Hi Thanks Harpo!
Yes you have right,
i extended the pins like this way,
https://goo.gl/photos/qDNCewJxkwi5xjbL7
Harpo said:Your pin extension only adresses the different pin spacing.
My remark is for the different pinout. Bottom view in clockwise order -
Multicomp: coil, switch pole1, normaly connected throw1, normaly open throw1 , normaly open throw2, normaly connected throw2, switch pole2, other side of non polarized coil.
Omron: coil, normaly connected throw1, switch pole1, normaly open throw1 , normaly open throw2, switch pole2, normaly connected throw2, other side of non polarized coil.
These are not the only differences, IE Omron current consumption for operating the coil is double of the Multicomp relais.
Already told you, fault fixing is about details.
Anyone?DrywOwens said:Hi everyone!
I have a question regarding a switchable turbo mod on my SSL clone. My "turbo section" is already integrated into my PCB. The trouble is that every time I switch it off (thereby summing L+R into one detector circuit), my gain reduction increases dramatically, making it difficult to make a fair A/B assessment. Of course this is to be expected, as the "turbo off" switch is summing the signals into one detector VCA, so that VCA is getting a hotter signal. I figure I can add some resistors to the "turbo off" switch position to trigger a 3db each, or 6 DB total reduction of the signals being summed to the detector VCA in order to avoid the excessive gain reduction. My question pertains to which value resistor(s) I should be using to attenuate the signals being summed to the detector VCA. Or, what impedance shall I use to calculate the resistor values? Sorry for the basic question and thanks in advance for answering!
spreadspell said:Thanks HARPO !
OK Now make sense ... So, i purchased now the HRS2H-S DC24V from Farnell (9480226).
i hope that the problem was there.
Thank you very much!![]()
just one of the little errors. For the +/-12VDC supplied sidechain part of the circuit you want a current setting 3K9 resistor connecting to this THAT2180 VCAs pin 5, so the turbo silkscreen shows the correct value for Iset (12V-4*0.7V diode drop)/3900 ohms=2.4mA and the 5K1 at the sidechain VCA on main board (would be only allowing 1.8mA) needs the change to 3K9. (Keep the 5K1 resistors at the +/-15VDC supplied THAT2180 audio VCAs).
