vertiges
[quote author="ixi"]
Hi, thx for answare vertiges .
compressor not work, it's thesame, when i connect 1+8 pin on stage of That chip.
i check and re-check 10 times
I don't any external sidechain board for now
Ok, i make foto and post here with voltages
[/quote]
1+8 ? You mean the pins of your VCAs ? What do you use by the way. THAT ? DBX ?
If you short the pins 1 to 8 of the socket of your VCAs, (with no ics, inside), your inputs go directely to your ouputs unaffected by any compression. It's the good way to know if your 5532s and 5534s are all rights.
eD
eD
