[quote author="ixi"][quote author="vertiges"][quote author="ixi"]Please for help :?
i finisht my first GSSL and now have one big problem :sad:
Compressor not work - not compresst !!!
I read this topic but i can't find what i do now.
When go sound true the compressor, is't sound good, without distortion, brums and .... but R ch. it's 2 times louder that L ch. :shock:
On control board work just makeup gain.
Any idea :roll:[/quote]
I lost my previous answer... strange...
ixi,
Do you mean you don't have any compression AND the sound is not good ?
Did you use any external sidechain board ?
Could you post some pics ? Could you give us the voltages you get at the rails + the ICs.
But first, you should check and re-check for shorts, bad solder or colder joints, wrong component values, etc.
And, the subjet of "no compression problem" have been troubleshooted a lot of times in this thread... You should have found a lot of infos or very useful procedures to help you by reading this thread.
Regards,
eD[/quote]
Hi, thxfor answare.
compressor not work, it's thesame, when i connect 1+7 pin on stage of That chip.
i check and re-check 10 times
I don't any external sidechain board for now
Ok, i make foto and post here with voltages
[/quote]
Ixi,
Could you delete this post ? (the one with 1+7)
You know you still can edit your post even after posted it, don't you ?
eD
