ncoak
excellent, thanks for clearing that up.
??? ??? ???ilfungo said:ciao
Can you tell me which switch I use to monitor simultaneously two super side-chain board?
thanks
ilfungo said:Ciao
no for Mnats but
I hope this can explain:
http://www.youtube.com/watch?v=Lv_wmlAWnkA
beatnik said:Hi everybody!
I need some help with my GSSL built from gyraf project. The clone isn't passing audio but the power section seems to be fine as the led lights up and the voltages from regulators seem to be ok.
Here are my voltage readings on the opamps, with no input signal. Please help me finding where some errors could be.
L&R inputs NE5534
pin1 -- 11,97
pin2 -- 0
pin3 -- 0
pin4 -- -15,09
pin5 -- -0,63
pin6 -- 0
pin7 -- 14,46
pin8 -- 11,96
L&R outputs NE5532
pin1 -- 13,76
pin2 -- -0,05
pin3 -- 0
pin4 -- -15,10
pin5 -- 8,10
pin6 -- 9,34
pin7 -- -13,86
pin8 -- 14,45
NE5534 on VCAs
pin1 -- 11,62
pin2 -- 0
pin3 -- 0
pin4 -- -15,12
pin5 -- -0,89
pin6 -- 0
pin7 -- 14,45
pin8 -- 11,65
TL072 & TL074 (some pins change voltage depending to the threshold pot)
pin1 -- -0,09 to 3,13
pin2 -- 0
pin3 -- 0
pin4 -- -12,18
pin5 -- 0
pin6 -- 0
pin7 -- 0
pin8 -- 11,89
pin1 -- -0,14 to 0,20
pin2 -- 0
pin3 -- 0
pin4 -- 11,89
pin5 -- 0
pin6 -- 0
pin7 -- -0,03 to 0
pin8 -- 0
pin9 -- 0
pin10 -- 0
pin11 -- -12,18
pin12 -- 0
pin13 -- 0
pin14 -- 0,22
With input resistor 27k in front of the audio-VCA you substitute the 15k feedback resistor at the following opamp stage by 2x 27k in parallel, giving non-standard-value 13k5. This will give you unity gain for balanced out operation.Alessio said:When I change the 2 15K resistors for 2 27k for the unity gain, I'm changing the INPUTS of the VCA? Not the output. That's right?
Just to have it clear...
mac said:Search back through the thread for 22uf and 100uf.... there is some chatter about using higher quality electros in certain places.
(easy way i have found to do this is to use the "print" feature and then cut and paste into a word doc - so you can search for individual terms through a long thread like this one)...
good luck,
Mac
