Harpo
sorry, misread your obviously part of the part of the release section. About 1.3sec attack would have been 270k series R from the attack switch with 6.8uF cap to gnd. [270k * 6.8 * 10^-6 / SQR(2)]. No exact numbers, as these are depending on level and current drive ability of the sending stage.ptron said:1 -hrmm.. which one would be the 1300 ms attack? 1m * .47u?..
2- how did you calculate the attack for each stage? id like to do that to be more precise!!
tbh i wanted actually one with attack VERY sharp (around 0.05ms one with mild attack (around from .2 - 1ms) and a long one (around 60 - 150 ms (to have a longer attack time for kick drums etc...)
Your wanted VERY sharp attack around 0.05ms, sure, what driving stage? The TL074 won't do this.
3 normal pots, wired as rheostats, substituting the 2 lorlin type rotary switches and the 3M3.4- the variable ones are rheostats ??
yes, min.value, couldn't get much lower with a TL07x in front.5 -and the 820R would that be the one on the attack switch pos1?
my sketch is more or less the same as the complete GSSL attack/release timing section, but variable without steps. For release, dialing the lower pot across the 6.8uF full ccw (shorting out the cap) giving a timing in range of previous steps 1 to 4 from the release switch, controlled by the upper pot across the 0.47uF cap. Dialing the upper pot full ccw and the lower pot cw giving a timing of previous step 5 for auto. Mix it to taste.6- the (auto) that you written there, does that mean the 6.8u loop is the second release time? (kinda the slower one of the 2)???
