Alessio
Am I sending too many amperes to the 2180? ???
I have some lacks of knowledge on these things...
Your scope is sensing signal voltages. Reread my last post, especially the word 'current'.Alessio said:...When I insert the VCA I can't see anymore signal on pin 1...
Yes. There are other differences as well. Pcb silkscreen is the latest version. (I'd use zero ohms instead, YMMV).sdR said:..there is a 470R on the PIN3 and 10K on the PIN5. Is it a mistake on the schematic ?..
How much difference and is this difference frequency dependant?PAGEN said:Hi. This is mayby a silly question. I don't seem to have the same gain out from the compressor. If I feed it with a stereo signal the left side are higher in volume out. Even if the signal in is exact the same volume.
And I dont have any place to adjust anything. Hard to explain. Works as expekted otherwise.
Att a picture of the mainbord. Any advsise.
ruckus328 said:Do yourself a favor, don't use crap electrolytic caps in the audio path.....it will sound....well............like crapAnd it has nothing to do with "audiophile". Electrolytics are generally not very desirable in the audio path to begin with, so when you do have to use them make sure they're of decent quality. I doesn't mean you have to spend $20 per cap, but it does mean don't spend a penny on each.
I recommend to use Panasonic FC or FM series. It will cost around a whopping $5 to do the whole audio section. If you want to spend about an extra $5, go with Elna Silmec II (digikey).
