MeToo2
It depends entirely on what you want to do with them. The standard (Aarhus) GSSL only needs a power switch and a bypass switch. There appears to be one normally open and one normally closed contact and a lamp (which is not switched) on these switches http://products.eao.com/media/zoom/piz12849_zoom.jpg The bypass switch needs DPDT, so that's no good, and the mains switch needs 250VAC switching and the max rating on these is 42V so that's no good either. But of course they could be used to switch a 24V relay.....wthrelfall said:I have a number of these EAO switches, does anyone know if they are suitable for use on the GSSL?
http://products.eao.com/index.php?IdTreeGroup=124&IdProduct=48307
thanks.
