Sure. Imbalance between L/R will be caused by differences in parts values, a broken trace/wire/connection or differences in signal level.Nanitlig said:Should I be able to plug unbalanced cables in and have the same level at both sides without floating anything?
Sure will work. Connecting ring and shield at a TRS socket is the same as inserting a TS plug into this TRS socket (except slightly higher contact resistance). Your previous post description is differing from this, talking about lifting the connection to the ring of your TRS socket.Does connecting ring and shield (1 and 3), or using TS plugs not work with ne5534 inputs?
No.Would the tilt have anything to do with both L and R colds connecting with the shield 0V.
So with same signal feed and comparing both L/R outputs, your mod is giving same conditions when lifting the left channel cold. Conclusion would be, a wrong part value between right channel cold in and NE5534-pin3, or more likely a broken trace or not working connection in this area.For whatever reason the only way I am able to get both ne5534 to output the same voltage I have to lift the left channel cold.
These don't have the same pinout. (pin 5).Tried swapping IC's around, and actually I replaced the ne5534's at the input stages with LT1357, same pinout, single channel op-amp.
For usual not needed.Should I use transformers to balance the unbalanced inputs? Like Jensen JT-11P-1?
PeteC said:Can anyone share the HPF details with me ( if there is a pcb layout i can etch thats even better !
Harpo said:You can't, but to make your box safe in case a mains wire inside comes loose, you'd have to connect this safety ground from your IEC to any conductive spot to the outside world (pot housing when metal knobs attached to metal/conducting spindle, sleve of unisolated TRS sockets, ..). This will not protect your circuit inside your plastic case from induced garbage (radiating transformer from a unit below/above, RF, neons, ...)wthrelfall said:Another question which I can't find the answer to: I am using a plastic case for the GSSL, how do I attach the ground or do I need to?
Nanitlig said:PeteC said:Can anyone share the HPF details with me ( if there is a pcb layout i can etch thats even better !
Here's a simple HPF setup that's quick and requires no new boards. Feed the signal from the two 47k resistors feeding the sidechain to one side of a DPDT switch. The off position returns to the 15k resister at the sidechain input. Connect the on position to the off position with the capacitor across the two contacts, on the switch itself. When switched on the signal will return through the capacitor and when off the signal will bypass the filter. I used a .047uF Wima 63V on mine, which will give you a 6dB/oct. at 225 Hz filter. No resistor is needed on the switch, because the 15k at the sidechain input going to ground completes the filter. The other half of the switch can be used to switch an LED if desired.
D: It could swim in milk ...wthrelfall said:So is it a bad idea to use a plastic case because it won't shield from interference? I was going to use plastic because A: It's cheap B: I don't care that it doesn't look authentic (it's the sound I care about) C: It will be easier to cut out the holes etc. But now I'm wondering if I've made a mistake, if noise/grounding is going to be an issue..
Nanitlig said:Here's how I set up my HPF. A SPDT will work for mono sidechain or a DPDT if you want to switch an LED also on the other half of the switch.
Unsolder the two 47k resistors from the board. Solder both 47k to a lead going to switch COM. Solder lead from OFF position to the 15k resistor at the sidechain input. Solder capcitor across the switch from ON position to OFF position. Pretty basic. Only need one capacitor with mono sidechain.
.047uF = 225Hz
.068uF = 156Hz
.1 uF = 106Hz
The 15K (in series with the 100pF) between ground and virtual ground has nothing to do with your HPF response. You could leave these 106kHz LPF parts out when using THAT218x VCAs.Nanitlig said:... I used a .047uF Wima 63V on mine, which will give you a 6dB/oct. at 225 Hz filter. No resistor is needed on the switch, because the 15k at the sidechain input going to ground completes the filter. The other half of the switch can be used to switch an LED if desired.
If you like it, keep it. It's all about music, not numbers.Nanitlig said:Sorry, I used an online calculator. At any rate, I like the .047uF, it is working well.
Every gain stage in audio (not DC) is a bandpass to a more or lesser degree. There is no such thing as infinite bandwidth. A DBX2150 from the originally gssl circuit has 14MHz less bandwidth at unity gain than a THAT218x, so this 15K/100pF LPF @ 106kHz might be useful with this ancient part.Does that not create a band-pass at the 15k?
IMHO you could leave the 15K resistor and the 100pF cap out when using a THAT218x.Do you suggest removing the 100pF and placing a jumper, using 2180?
As already said, this 15K resistor is not part of your HPF. The resistive element of your 1st.order HPF are the 47K summing resistors and assume both R/L inputs of your stereo compressor are driven from a correlated signal source.With the 15k there I will still have the HPF, correct?
The HPF cutoff frequency is defined where your amplitude has dropped by -3dB (-45° phase angle). Your dB readings will change with a different ratio setting. There is no standard 1:1 ratio setting in the GSSL sidechain section.When I set -6dB reduction at 1k and sweep down, reduction decreases starting around 300Hz, at 225Hz reads -5dB, 160Hz reads -3dB and 85Hz reads 0dB. Then bypassing the filter returns the meter to -6dB at 85Hz??
Harpo said:If you like it, keep it. It's all about music, not numbers.Nanitlig said:Sorry, I used an online calculator. At any rate, I like the .047uF, it is working well.
Something like this.wthrelfall said:would you be able to post a picture similiar to Nanitlig's one showing your method?
