Ngr said:
MeToo2 said:
If you vary the makeup gain pot, does the voltage on pin 7 change and pin 1 stay constant?
If you vary the threshold pot, does the voltage on pin 7 stay constant and pin 1 change?
Yes to both of your questions
Then the problem would appear to be earlier in the side chain then.
As Harpo suggests, your fault could be/ is likely to be purely mechanical, so make sure you check the connector from the main board to the control board.
You can also check through the side chain by generating a constant sine wave in your DAW and connecting it to the input of your GSSL.
Switch on and off the DAW signal generator and check for changes in AC volts measurements at:
Pin6 NE5534. Should be same on both channels and a debalanced version of the DAW signal.
Pin 7 TL074. Should be an attenuated or amplified version of the DAW signal. It's amplitude should vary when you rotate the threshold pot.
Pin1 & 14 of the TL074 should be a compressed version of the DAW signal. It should change when you change the ratio switch when you have a low threshold and a high signal. It may well look very distorted (normal) as this stage is very non-linear.
Check the pole of the bypass switch. This should be always be a negative AC voltage that varies as you alter the DAW level and the threshold level.
Also check that the bypass switch isn't shorting to Earth.
Pin 10 of the TL074 (point 'o') should be a rectified and smoothed negative DC control voltage that decays slowly over time as the DAW single is turned off (assuming you are using the longest release time).
Pin 8 of the TL074 likewise
Note: if you have a scope that these waveforms in the side chain will not be sine waves.....
