MeToo2
Spencerleehorton said:ok,
the 10r resistor from the 7815 measures 23.14v, the 22r is -1.121v same as +15v rail.
The electrolytic 22uf + side is 14.99v
other side of 22r is -0.964v
all diodes are correct way and all electrolytics are correct way!
regards
Spence.
There's multiple 22uF caps (6 off), so it might help if you post a picture with the location of your measurements attached.
For the positive rails that'd be locations A-E and for the negative rails A'-E' all relative to 0V signal ground.
OK If I've understood you correctly. The input to the PSU at point A is around 23V which looks OK.
The current on the 10R is (point A - Point B )/10 = (23.14-22v) /10R = 114 mA.
Looks quite high but not unreasonable depending on lamps etc.
The output of the 7815 is +15V (22uF cap connected to 7815), which is correct.
But the 15V rail is measuring low @ point C = -1.121v.
So it looks like there's a dry solder joint or broken track around that area, or you've forgotten a jumper.
Suggest you trace the tracks and check where the voltage drop occurs.
