frazzman
Gustav said:frazzman said:Thanks Greg.
Looks like my switch for switchable HPF cap will work fine. This looks like a pretty quick and easy way to implement an SC HPF. I haven't finished building the rev 11 circuit but I wired up the switch and measured capacitance at each position and it was all good. I left out the 40hz position for now...
The math fails me when it comes to calculating the required value, Gyraf or Harpo or other mathematically-ept members able to provide required cap value for 40hz HPF ? Much appreciated
I am not smart enough to determine the impedance at the HPF point, but I think Jakob said to expect 10K.
You can use this calculator to find the corner frequency.
Looks like 400nF should give you 40Hz, but empirical testing never hurts
http://www.sengpielaudio.com/calculator-RCpad.htm
Gustav
Thanks Gustav. Looks like you got to the same point as me, I couldn't work out R at HPF either...
However in saying that, by virtue of "reverse engineering" - Jacob already posted the 3 cap values I used. He said 220nf gives you 80hz HP, so using the calculator - for the corner freq to be 80hz and the cap value is 0.22uf - R has to be ~9000R - which gives you 80.38hz.
So for 40hz - ideal cap value is 0.44uf which gives you 40.19hz with R @ 9k. I don't think that cap value exists, with nearest alternative (0.47uf?) you get 37.63hz. With 0.4uf you get 44.21hz. Same deal I guess!
Thanks for your help
