A current limiting/voltage dropping resistor has a power rating. Maybe yours was insufficient.Rocinante said:..But now the 10r resistor is smoking.
Doesn't say much without saying what's the (probably too high) voltage in front of this resistor in respect to 0V reference voltage.Through another suggestion found on this thread I increased the resistance to 100r. It helped as nothing smoked for 1 minute but then poof.
Vreg getting hot is related to voltage differential between vreg input/output times current drawn. 10R or 100R resistor burning up is a too low power rating, caused by excessive power consumption of a f.i. broken 22uF cap in front of or after the vreg or a f.i. broken active device such as TL072, TL074 or the sidechain VCA.The lm78l12 no longer gets hot but now that resistor burns up.
Take out prementioned +/-12VDC operated chips as well and replace the burned up resistor. Rectifier will be operating correctly, else the other rails would have a problem as well. After powering on, if vreg still gets hot, replace the broken 22uF cap after the vreg. If resistor still burns up but vreg stays cool, replace the broken 22uF cap in front of the vreg. If resistor doesn't burn up and vreg stays cool, power down, refit 1st opamp and power on again. All fine, power down, refit the 2nd opamp and power on again. All fine, power down, refit the sidechain VCA an power on again....I took out the led on the control board.
There are two, one in front of the vreg, the other after the vreg...Rocinante said:... So I was about to replace the 22uf ...
Sinkia said:Hi everybody !
I'm finally ending building a really simple GSSL I bought from Gustav !
I just have one concern regarding the power supply wiring...
On his doncumentation, it show you have to make the secondary 30V, and the wire only those 3 points to the PCB.
I'm a bit of a junior, and I'm just wondering if this the right things to do ?
Many thanks all
Sinkia
Nothing to do with your 10R smoking...Rocinante said:I got arrogant and overlooked the 1k resistors in the vca circuit.
Well I also had the latch up problem with l78l12 and replaced everything that used the +12v line including the 78l12. The UA78l12 was the final one I put in there but maybe it was a number of things so I am not exactly sure if it was the UA or the tl072 or tl074.Harpo said:Nothing to do with your 10R smoking...
