Hey all, first post.
Have tried to read lots and lots of posts and it made me understand quite a lot about how these electronics should or shouldn't work and at the same time made somewhat more confused so I will give a go and try to describe my problems and hopefully it will all be ok (meaning that I didn't miss any search stuff
Have built with PCBgrinder pcb.
1. The unit powers up, does not compress (the meter is always at 0), and all the controls have no impact on anything, bypass, sidechain switch, attack, release, ratio, treshold and makeup do nothing.
2. The unit passes sound, but at a very low volume, I have checked the audio signal with audio probe and the signal is ok till it reaches 27k resistors before going into VCA. and when it hits the output it's a much quieter 30 or more -dB and it sounds like something from a reverb tank and a big low pass filter on. When powered touching pin 1 on VCA there is no sound but unpowered there is none tha same on sidechane THAT and pin 1 (trought the audio probe).
3. And interestingly if I put it into audio interface the input dB levels are normal near 0 in the daw but as I said the sound is very quiet and the input can easily oscalate even on the low imputs, i can only connect to imputs with pads pushed otherwise it instantly oscalates.
I'm using THAT2181, and this layout http://www.gyraf.dk/gy_pd/ssl/ssl.pdf. My THAT's are not pretrimmed and I have no way currently to trim them, maybe this is the problem?
1. All the voltages according to this http://www.gyraf.dk/gy_pd/ssl/ssl_sch.gif -12 or +12 and -15 and +15 are correct.
2. Tried bridging the vca pins 1 and 8 without THAT, the output and the sound is the same as with THAT inplace
What should I do, where should I look, I suppose first thing I should get is a good signal then i can continue to the compression problem.
Sorry if I missed a post where someone had a similar problem.
