What reading do you get when measuring across the individual pins of the makeup gain pot ? Especially from pot wiper pin. You should get between 0VDC to 12VDC when rotating the knob. And this same DC voltage should go directly thru your switch to the 620K. (--Could also check for connectivity with beeper--).
If it DOES show across the pot pins but NOT at the 620K resistor, your bypass switching is wrong.
If it DOES show across pot wiper pin to other pot pin but does NOT show between pot wiper pin and chassis ground, you are missing the connection between signal ground and chassis ground.
And if it does NOT show across the pot pins, your pot either doesn't connect properly to 12VDC and/or GND, or the unit is not switched on, or you are measuring wrong.
(I never implemented the bypass there. I hardwired that connection to constantly "in". I think switching there is a useless feature. Instead I use relays for hard bypassing the unit
