Ok everyone, just a couple of quick questions.
I've had a read throught the 60 pages of this thread and some searches and found some info. Just wanna double check i'm heading in right direction :thumb:
Firstly, when I got mt GSSL goin, I got too excited and forgot to do the earth @ pin1 input, and I also had my tants on the control board backwards. Got distortion. which is to be expected from what I've read with other probs have had. (AC instead of DC etc etc)
I've now reversed the tants and grounded my input pin1. Still distorting I read that tants may not survive bein the wrong way round. correct?
Secondly, when I was changing the pin on the release switch, all my pins fell of the rotary switches. No prob I thought to myself. But................when I put the ratio one back on for three selections, now only one ratio seems to work, and I'm sure it was fine before that. If I take the pin out again, i get mostly no sound on any of the selections, and only two working ratios, in random spots on the switch. I made sure I had the switch all the way counter clockwise before i put the pin in. weird :?
I checked for shorts & bad solder joints. None that I could see. I looked at the pcb. obviously only the first three pins are actually goin anywhere on the curcuit. arrrrgggghhh!!! :evil: Do I have a bad switch? Or have I done something stupid when all the washers fell off the board?
And lastly, I went and got some new tants from jaycar (codes from Kevs list) but when I got home, they looked real different. No + sign or a longer leg. Thats not a tant then is it? or is it? I double checked the code and all. Maybe the assistant gave me a ceramic? I'll prob just order some from farnell to be sure.
Well, thats my rave over :green: Thanks for listening. I knwo the frist prob has been covered before, but I don't think I've seen my second prob anywhere.
regards
Steve
