Diyr's
Just in case anyone else has this issue in the future, I made the call to Sifam. The information I recieved is that the 39.3mm with two 2.4mm mounting stud holes on a 44.4mm diameter at 45 degrees is the correct panel cutout for the PPM Type 14 meter. I also found out the that the "Director" PPM type 14 and the Sifam PPM type 14 are the same meter.
For those interested, I have designed my own PCB for a SSL style compressor. It operates as dual mono or stereo. I made some initial tests using the the Rightmark Audio analyzer through an RME Multiface. The results were good.
Freq. Response: -0.5dB @10Hz and -2.5@ 30kHz
Noise Level, dB(A): -105.2
Dynamic Range, dB(A): 105
THD %: 0.052
IMD + Noise %: .419
These were all taken with the compressor "in", 2:1 ratio, 5dB of gain reduction and 5dB of makeup gain. Not much use to me to test in the bypass mode! I hope to test again using the Audio Precision Test set to get rock solid measurments and also get rid of the A weighting. The only one I'm concerned about is the IMD. Not sure what it should be using THAT 2151 VCA's and 5534AN input, 5532AN output opamps. In my listening tests the unit sounded very good.
I also designed a hearty power supply PCB to go along with this device. All works perfectly (so far). Once I get the panel completed I'll post some pics.
Regards,
Jeff
