Well, it still doesn't sound right that you are getting asymmetrical voltage off the transformer. Both transformers are giving you the same asymmetric voltages?! Test and double test. Call Digikey or wherever you bought them and ask to talk to a tech and tell him you are getting the asymmetrical voltages, describe how you wired them and test them. Maybe you can return them for new ones.
Will do.
I suspect something is wrong in the chain between transformer and regulator. Are you installing the rectifier correctly?
Yes. The rectifier is installed correctly w/ + on +. Installed on the upper left corner for 115vac.
No, the transformer delivers two seperate positive voltages, if wired correctly. The rectifier converts it to pos and neg.
I'll triple check again. I checked it all, but didn't write it down.
Yes, it's possible you have a bad batch of regulators, but unlikely.
I just went and picked up some different reg's here locally. I'll give them a try.
First make sure your toroids are working correct, they are wired correct, the rectifier is giving correct plus and minus and the regulators are recieving the plus and minus and ground correctly (you might want to check that without regs in place). If all that is fine, then you can try more regulators.
From what I could tell, all was good up to the point of the regulator. Voltage was stable at 28.xx Vac. The + (7815) works just fine. I can have it plugged in. All else is good until I plug in that 7915, and it cooks.
If your 7915 is getting AC, then you have a problem. It should be getting DC! Maybe this is your issue. That would mean your rectifier is not working. Double check your rectifiers. Check their output voltage! It should be symmetrical, pos and neg DC!
The input of both the 7815 and 7915 (center pin) is receiving AC voltage, but the 7815 works fine, and sends +14.80 VDC output. It was my understanding that the rectifier was suppose to do the voltage conversion, not the regulators??? Could it be I have bad rectifiers?
How is your transformer wired to the board? The upper left of the board near the rectifier? Or where the onboard transformer would go? You may have an error there, bypassing the rectifier by mistake. That would explain it!
Yes, the upper left corner. The transformer is wired as such:
Primaries: Black/Violet is hot w/ 115vac. The Red/Yellow is connected to the Neutral of the IEC connector. I've double checked the voltages going into the transformer, and we have a solid connection.
Secondaries: Red/Brown tied together and going to the center pin of the connector on the board. The Blue and Green are on the 2 outside pins.
Make sure your test meter is accurate. Test it on some known sources. (I had one go bad on me recently and it cost me several days of weird readings and screw ups.)
That was the first thing I did last week.
I'd post pix, but it doesn't appear that option is available on this thread??
