OK folks, my first DIY build is nearly finished, ( might throw some sort of christening party or take it to my local parish ).
Theres just some things i would like to clarify in regards to the wiring, before i switch my baby on. Here goes.
On my bypass switch i have wired up the A and C terminals but im confused when it says in gyraffs layout...ON and OFF go to c1 and c2 and another goes to R2, my switch has the A,B,C,D in the centre but is just labelled 1-12 on the outside. can someone please clarify this for me.
Also i need help with wiring the grounds. Ive twisted the two wires labelled 0v from my power trafo together and sent these to the middle pin on the external ac in connector, YES ?
The 0v from the input connector has been soldered to pin 1 of my RIGHT xlr...do i then take a wire from the same pin and connect it to pin 1 of my LEFT xlr ? And the same obviously to the output section.
And one last question before i power up, there is a ground, i presume 0v on my IEC fuse thingy, what do i connect to that ?
I know this may be a bore to answer but if you could help me out ild be grateful :thumb:
