Interestingly, the waveform was not present at Pin 8 of THAT 2181 in the master sidechain VCA. Nor at Pin 6 of TL074. It was present at Pin 7 of TL074. These images below are from Pin 7 of the TL074.
Does this mean the TLO74 is causing the distortion? This image is typical of my previous test sessions. I have seen it dramatically worse on the sine wave. Moving release to a longer setting clears up the sine wave.
Ratio 1:10, short release.
Same ratio, longer release.
Scope settings: Volts .05, Time .5ms. AC and DC triggering were the exact same wave.
So, I have many questions. What are we seeing here? What is normal? What is distortion? Why do the waves go flat at other test points with the longer release? Ultimately, where can this be coming from?
We previously hypothosized it was coming from the rectifier stage or the A/R circuit. However, if it is showing up at the first output of the TLo74, as in these images, that is before the rectifier and way before the A/R circuit. And it is not present at the master VCA output. Why is the release setting affecting the wave all the way back at Pin 7? I'm stumped.
