iangomes
regularjohn said:and I worry that you've built these for other people.iangomes said:It sounds to me like the ratio is too high at 2:1. Maybe I should open my unit back up and do a ratio modification of some sort.
??? That's an odd thing to say right off the bat.
Otherwise, thanks for the input regularjohn. I do have the trim-pots in and I did adjust the resistors for my vca's. I'm pretty sure my GR meter is accurate, but I'm going to do a couple of tests to be sure when I get home tonight.
MikoKensington , I think we're on the same page. Grabby is definitely the word I would use to describe it. Sometimes is works if I have a mix with a lot of dynamics, but on a dense mix, I find you have to be really careful with it.
