ptron said:
..BUT! they wont fit in the holes!!!
they are too big. do i have to buy different terminals?? if so what sort of diameter should the pin be? should i dremel these? to take lil bit off from the pins .. see if that works? ;D
btw my diodes didnt fit either..
what diameter lead should they be?
Brilliant plan. :
Sounds like turning the ceiling when a light bulb in your room needs exchange. ;D
The right tool for the job probably is a
drill to get the diameter of your holes larger.
If the pcb has plated thru holes and the part in question connects to top and bottom side of the pcb thru this drill hole, just solder on top and bottom side.
