Harpo
Ilfungo, this is a DIY forum, not paint-by-numbers, so you'll have to do some homework for yourself, especially when your requests are constantly missing neccessary information. ![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Switching the sidechainfilters with your 2x8 rotary switch, use the 1st.deck for the 1st.filterboard and the 2nd.deck for the other board, as described by barcleycon (to my knowledge the SSC-boards, Gustav is selling).
For GSSL bypass with illuminated switch see my previous post for a possible solution.
For Turbo bypass see my ugly scribble from pg.7 to get the idea. Just substitute the DPDT switch with your 12V whatever type and pinout, might already be a DPDT relais (are part numbers so hard to read?) and activate it as forementioned described with your -for whatever LED voltage- illuminated probably not EAO switch (these come with more than 3 pins, two alone for illumination). You might power the relais coils from your +15V rail, or use a voltage dropping resistor when powered from raw DC pre regulator.
All information needed probably is within this thread, so you will have to read a little.
Good luck.
Good luck.
