kosty
I know the external SC Output and Input are unbalanced. Is it theoretically possible to make them balanced by having a custom PCB with the same input and output stage as the GSSL Board for balancing / de-balancing ?
..is a 24VDC standard type relais with 1152R coil resistance (Omron has a high sensivity type as well).G-Sun said:200r realy:
Is this right
http://no.farnell.com/omron-electronic-components/g5v-2-24dc/relay-pcb-dpdt-24vdc-2a/dp/9949500
Thanks a lot!Harpo said:You probably/maybe want http://no.farnell.com/multicomp/hrs2h-s-dc24v/relay-dpdt-2a-24vdc-tht/dp/9480226
a nominal 24VDC DPDT high sensivity relais with 2880R coil resistance (less than half the current demand of your linked omron relay and with the additional benefit of only 2/3rd the cost).
Have to check that on an older computer. Mine is running with Linux and Sprint Layout didn't seem to like Wine the last time I tried.febo2609 said:PDF wil be ok.
The turbo board is a completely different thing. It is basically just a clone of the sideboard circuit already in the GSSL so with it the GSSL uses a stereo sideboard path and without it mixes stereo down to mono.ilfungo said:Where i can find schematics of turbo pcb?
