Hi guys,
I own a nice build of a GSSL with turbo mod and dbx202c gold can VCAs which I calibrated following the various instructions on this board (for least VCA distortion and correct ratios). While I like the sound of the unit I was still having doubts when compared to an original SSL.
I do not have an original here to compare it to, but I found this ancient thread on Gearslutz:
https://www.gearslutz.com/board/high-end/59093-waves-ssl-vs-ssl-fx-g384-vs-urs-1980-advanced-test.html
I created my own file for the drums only test using the GSSL, following the settings from the thread and trying out several threshold & makeup settings for the best cancellation of the files:
https://www.gearslutz.com/board/11817578-post239.html
original files in post 2:
https://www.gearslutz.com/board/592712-post2.html
Settings:
Ratio 4, Attack 3ms, release 0.3, gain reduction hitting 8db
When comparing my GSSL file with the FXG384 from the thread, I somehow find the 384 fatter, weightier, more "attitude", the GSSL being cleaner, a little thinner, a little more spikey. Is that the sound difference you would expect from a GSSL?
I guess my question is, how can I get my GSSL even closer to the 384?
Could it be the ratio or VCA distortion adjustment? Are there any adjustments/mods I can do to get it more in the direction of the 384?
Settings:
