Hi guys!
Just finished building the Gyraf G9 and I have three problems. I'm just throwing a bone to see if any of the following problems are anything you've heard about before:
1, A wierd problem. It seems to run fine for a couple of minutes, but then shuts down. Seems like it has to cool down before it can restart again.
(I use heatsinks for all the transistors except TIP121)
2, The output volume differs a lot between the two channels. Assuming the the tubes are OK, what else could it be?
Thanks in advance
Thanks in advance
