tylerrussell
New member
- Joined
- Sep 30, 2013
- Messages
- 2
Hi, all. Very new(bie) here. Hope there's some input available. My Hafler TA 1100 started distorting some in one of the channels. A post from 2006 indicated this:
Ok, this was a weird one! I emailed Hafler yesterday and a tech emailed me back and said to remove C21 and C22, and put a .47uF between pins 6 and 7 of U2B, and to duplicate the mod on the other channel before it goes bad as well. I only had one .47 lying around, so I gave it a try on the defective channel and it WORKS! Looks like a design flaw, huh? :thumb:
I'd like to try this, since when I opened the top of the unit one of the caps fell off the board! Getting C21 and C22 off is no problem (one's gone anyways) My question is~is this a polarized cap? And where is "between pins 6 and 7"? Here's someone's link to the schematic: http://mywebpages.comcast.net/tamron1958/Schematic.pdf Since the schematic is not clear to me; does the .47 go from the + of the now removed C22 connection point to the - of the C21 connection point? Since the unit is un-usable as is. thought I'd give this a shot. I have a soldering station and have done minor R&R on guitar amps successfully. Thank you for your time!
