Brotastic said:For the bypass do i need something else.....ie another board or anything?
Echo North said:Brotastic said:For the bypass do i need something else.....ie another board or anything?
What do you mean by "bypass". The 1176 doesn't have a true bypass, just a GR off. The GR off is usually placed as a switch on the attack pot.
Brotastic said:Echo North said:Brotastic said:For the bypass do i need something else.....ie another board or anything?
so, on the front panel of the 2-1176 it has a place for a bypass.......is that not a true bypass? I apologize for my ignorance.
Echo North said:Well the way you have it linking would be engaged with the switch in the down position.
Do you have the onboard wire jumper installed? it's net to the info text on the PCB.
Echo North said:You should see summed audio coming out of the "link" pad.
Autophase said:Hi guys I have decided to build a stereo 1176, well 2 actually one for me and one for a friend.
I obviously intend to use the stereo link kit and I will get matched pairs from hairball, but I have 2 questions.
1: can I easily make the stereo compressor use a single set of controls as opposed to having 2 sets of mono controls, or.would you suggest it's better to have them both available to help with adjustments for tracking differences?
2: which revision is best if I intend to stereo link? I see a lot of you using revision D. Does it make a difference?
Autophase said:1: can I easily make the stereo compressor use a single set of controls as opposed to having 2 sets of mono controls, or.would you suggest it's better to have them both available to help with adjustments for tracking differences?
Autophase said:2: which revision is best if I intend to stereo link? I see a lot of you using revision D. Does it make a difference?
germoju said:hi guys,
i'm linking my units with the stereo kit BUT ... (!!??!!) i got questions!
1- for the sidechain, I have to use a mono jack ? or stereo jack ? or nevermind ?
2 - On the stereo card, the ground goes to ground of the jack, right ?
3 - the +30V test point goes to +30V on main PCB R87 ?
4 -the IN goes to one pin of the jack ? And OUT goes to the other, right?
Sorry , I read all documentation but I too novice !
Please can ou help me with that ?
mnats said:Can you easily find a dual T pad with a single shaft?
emrr said:mnats said:Can you easily find a dual T pad with a single shaft?
Yes, vintage Daven on ebay, but it's gonna cost you around $400.
Or buy a Goldpoint, also really expensive.
