earthsled
Hi there.. Did it work? Thanks a lot!
Yes, this wiring worked for me.
I also found that my unit needed a connection between audio ground and the chassis to function properly.
Cheers!
ricothetroll said:Hi,
My problem is when I switch it to be stereo, I have a the 2nd unit that has a (measured) gain reduction of about 2dB more than the first unit. My test procedure is : in dual mode, both channels are fed with the same signal (ch1 from the L output of my soundcard and ch2 from the right one), I scoped both signals at test point 2 - right after the input gain pot - to make sure both compressors are fed with the same signal, I then set the out pot in bypass mode to have unity gain in both units. Then I switch both units to GR and measure both outputs, and see that both gain reduction is the same. When I switch the link switch to link mode, I measure a 2dB difference between ch1 and ch2, that is to say there is a 2dB difference in gain reduction. Meters also display a 2dB difference between the two channels.
lowend said:Hello,
I finished 2x 1176 Revision A with the stereo link PCB. But I cant understand what happen. When I'm in Dual Mono mode, all is fine. Compression is normal etc.... But when I switch to stereo, Compression is very heavy !
I've made a video, please take a look : http://youtu.be/lybZ44KPct0
I hope someone has the same problem to get an issue !Cause I really dont understand... I check all wires, voltage etc...
Echo North said:lowend said:Hello,
Clean builds!
Do you have the link wire by the PCB link board writing installed?
earthsled said:lowend: double check the orientation of the op-amps on your stereo PCBs -- these are easy to get backwards.![]()
Echo North said:You've followed this?
http://hairballaudio.com/guides/Stereo_Link_Wiring_Guide.pdf
your ins are connected to your outs?
Check that your PCB has +30 at the pad and voltages at the op-amp supply pins. Make sure you have continuity to ground at the GND pad.
Mike
Done !Echo North said:Send me an email and I'll get a replacement out to you.
Mike
Janzoulou said:Hello everybody... I am wiring now the Stereo-link board inside my dual 1176 REV A. One (maybe silly) question:
Referring to the graphic from ricothetroll on ratio-board pad17 and output-pot - pads staying empty??
Cheers and excuse if this question is stupid.. just want to be safe.
Ok... this one is solved. Now i got the same problem like germoju posted above... GR changes on one side around 2-3dB when the sidchain is linked via the Stereo-boards.. Anybody got an idea?
