Echo North
Yes do it.
You need to connect those points with a piece of wire or cut component leg.
Echo North said:Yes do it.
late said:Do i need connect output pot directly to chassis or how? And it give noise only when output pot body get contact from chassis.
germoju said:late said:Do i need connect output pot directly to chassis or how? And it give noise only when output pot body get contact from chassis.
Stereo link must be wire to chassis Ground...
Output pot to main board 16 - 15 - 17
late said:germoju said:late said:Do i need connect output pot directly to chassis or how? And it give noise only when output pot body get contact from chassis.
Still same problem. I think that my wiring is right. Because it work well if get touch from the case. Some grounding issue.
PSU will NOT work.germoju said:I also have a question about PSU wiring...
I'm not sure to be good on that... I did a draw too
Someone can tell me if I'm ok please ?
earthsled said:Hi all,
I'm having issues using the stereo link kit with the ROTARY switch boards.
My first attempt was to follow the PDF posted at Hairball Audio.
When I switch into stereo link, my output level drops to almost nothing and sounds thin.
Earlier in this topic, ricothetroll provided a link to an alternative wiring diagram (attached).
Has this approach been successful?
Thanks for your help!
hi, I wire my unit like this and it works well...
earthsled said:hi, I wire my unit like this and it works well...
Thank you germoju! I will give this a try...
