living sounds
I have tried to contact him via various channels but didn't get an answer. I've read that he does sell capsules separately though. Did anyone here have more luck?
Exactly. And Braingasm has some interesting stuff on their website.I was kind of curious about this too. Apparently, Stam is using their capsules now.
Dachman supplies the same capsules yes. I'll send you a PM tooThanks guys! I already emailed 3U earlier today. If I can't get it from them, is there anyone else that would supply it? Dachman? Anyone in the EU?
Does Dachman specificy what they carry? Cause there are dark K67s (hence Maiku's darker K67) and standard bright ones, then they also have the "bright" "CK12s", then the slightly darker (presence boost of 3.5 to 4dB) "CK12s" (which also explains Maiku's darker edge terminated ones if they do use 3U as I've heard).Dachman supplies the same capsules yes. I'll send you a PM too
Not AFAIK. You could email joshDoes Dachman specificy what they carry? Cause there are dark K67s (hence Maiku's darker K67) and standard bright ones, then they also have the "bright" "CK12s", then the slightly darker (presence boost of 3.5 to 4dB) "CK12s" (which also explains Maiku's darker edge terminated ones if they do use 3U as I've heard).
Is the K47 you have the Warbler MKIID one? Also agreed with the others, transparency is good and I'm more likely to buy from an honest seller of parts.Yes, Soliloqueen is correct. My capsules are sourced direct from 3U. I am happy to support the GroupDIY community by offering an unadvertised discount. Just PM me if you need something. I do not have the "dark" versions.
Is this really true? Or speculation?Braingasm is using stock 3U capsules with rebrand on them.
Before you ask how do i know, check the pattern of the holes on their k87 on their Instagram profile. 3U is the only company making capsules with this pattern. The rest is obvious. Wires, screws, materials, tension rings, copper spacers...
Stam is also 3U.
I'm not sure exactly which part, but above you have the Braingasm owner confirming this, and Stam-3U relation is at this point common knowledge.Is this really true? Or speculation?
Which user is the Braingasm owner?I'm not sure exactly which part, but above you have the Braingasm owner confirming this, and Stam-3U relation is at this point common knowledge.
