My older very nice dumb HDTV failed, it had good picture and sound.
It is a one board type, checked some caps in the suspect area and they test good for value, ESR and leakage. I found a schematic and will continue to try to fix it.
I am looking for a replacement board or a used TV
Looking for a new dumb 1080P HDTV is a challenge.
Found one however the screen is not as good (off to the side view is not good) and the sound is not good, it sounds like a bad speaker enclosure area design issue.
I can connect it to the stereo by the optical link however the stereo is used for music and movies, for regular TV I don't care to power it up no reason to waste the power.
That is the back ground
Has anyone used the stock HDTV amps to power external speakers?
It would be easy enough to disconnect the inside speakers and connect to external speakers.
The reason I ask is I have not found any information if companies use a fixed EQ for the amps in the TV that might not match well to nice external speakers
and if it has a class D amp is there anything else I need to know to load it properly.
