iprovlek
Great work Paolo!
Is there progress on it!?
iprovlek said:Great work Paolo!
Winston O'Boogie said:Nice work Paulo
I like that you've made the amplifier boards as daughter cards for ease of switching, fixing, building etc. but not constrained yourself to the usual 990 footprint and sizing enabling you to get more stuff on the cards.
Did you come up with your own format in terms of pin locations etc? Or is there a standard other than 990/2520?
I'm working on a similarly sized amp board but can't seem to decide on a standard to stick to.
Anyway, looking good so far fella![]()
Great to read Paolo. I'm so excited to see this as your work thus far has been very remarkable.
pahstah said:Thank you John,
The format is an idea of mine, nothing really special.
the idea behind the boards is to have the capability to insert them vertically like a 990/2520 footprint but also horizontally into a connector with a 2.54 mm pin space. So if someone is going to use them in a more point to point build like the original modules he has the ability to do it.
it is also practical so i can insert them in a breadboard to run test for them.
pahstah said:the main problem is oscillation above 70 db of gain with the 1:10 tap inserted, no oscilation with the 1:1 tap.
