Electrobumps said:people getting picky about spelling and spouting off about how many consoles they designed. ???
Electrobumps said:I don't know your credentials just as you don't know mine.
Whoops said:You should know, it's next to Doug's nickname, 7066
Squeaky said:The whole balancing act with headroom that I have and will continue to be going through is an interesting exercise for someone like me who only has a basic understanding. I'm probably going to be doing it more by feel that numbers, although I will check the numbers where I can.
Squeaky said:I've been recently trying to get the gain-staging sorted for my ongoing (looks to be lifelong) project of building a rudimentary 16 channel (12 channel, 4 returns) console based on Helios amplifiers and routing topology (more or less). I'm trying to use the 2128 amp as a fader buffer(24V) and found that at first I was smacking the buffer way to hard with the output from the 22113 line driver (using nominal 34 - 36V)that I was using in the mic pre. I dialed the 22113 back a bit (feedback resistor) and it seems to be behaving better. The little 2128 buffer in the router will definitely contribute to the sound if you are not careful (many will of course argue that there isn't supposed to be a sound if you are doing it right). I'll probably try and negotiate my way carefully along the edge with 22113 gain. I don't want to raise the feedback resistor back too high on the 22113.
The router module has a pan, mono and cut switches, meter select (pre/post fader) and 2 sends with pans (one of the sends switchable pre/post). Like I said, rudimentary.
I had to think a bit about how to not load the 2128 output too much, remains to be seen whether I have done that adequately. I only have one Helios schematic showing fader makeup and the amps are not identified. I ended up doing the sends a bit differently to the schematic (for better or worst).
At the moment I'm deciding whether I should use bus transformers (free gain but bandwidth limiting) or stick with the original transformerless philosophy (potentially greater electronic noise).
There is little headroom improvement in going from 24V to 36V (just 3.5dB). If you run internally at -8dBu your headroom will be fine on a 24V system. Noise always increases with gain. At high gains, layout, screening, general construction decoupling and wiring are are as important as design in determining noise. There is no reason why those old designs should not comfortably exceed and EIN of --120dBu.Rocinante said:I wish my noise/headroom issues was to do with a Helios mixer. Some of the Helios mic preamps/eq's I built had headroom/noise issues. 36V made an excellent mic preamp if kept at lower gain. At higher gain settings noise became noticeable. I too used 2128 and 22113 cards (I should redo the 22113 as i could have made it much smaller). Input is a Jensen (or Cinemag) 1:10 input transformer, while for the output I used a Cinemag quadlifier, like used in the API type builds.
The ones I used 24V with had no noise issues but not a ton of headroom either. That said they are still good mic preamps and have a distinct sound that I definitely like. Recording guitars through U87 and the Helios with eq engaged, the mid and high range really place the guitar in that sweet spot that makes the work I put into them pay off.
I am still working on the 36V ones.
You would do that for a symmetrical output stage, where both sides are capable of delivering enough current to the load.ruffrecords said:For maximum headroom you would normally aim to bias the output transistor to close to half the rail voltage
Electrobumps said:1073 pre I will often crank the gain on a snare for some crunch and back the output right back as not to clip my DAW, "technically" on paper stupid. sonically this can sound amazing. Do this on an SSL mic pre, it will sound like a disaster.
